Old 12-15-2021, 12:36 PM   #393 (permalink)
racprops
Originally Posted by tomi_k View Post
Ah okay... Well, how he did may not have been "a good idea" but principle seems to be the same.... vaporize gasoline...
Sadly it is about the same as saying I have a idea to run cars on Gasoline.
Cars only run on vapor. The problem is currently we make it vaporize in a few microseconds within the combustion chamber, and what is not vaporized in time to make power is left to burn during the rest of the cycle, as they leave the combustion chamber, pass the exhaust valves down the exhaust manifolds down the exhaust pipes to the cats where they try to burn off the remaining unburned fuel.
ICEs are said to only be 30% (at best) efferent, that means 70% of the fuel put into them are wasted.
IF we could vaporize the fuel within seconds of its input to the combustion chamber it is claimed to than only need that 30% to drive the car and that 30% will be completely burned and thus no waste and no major pollution.
Oh by the way 70% savings on fuel use and cost..
Rich
