A mini box which can handle heat and pressure.... using resistance wire or something with 12V to create heat (a heat coil)... one side of the box is for the heat coil, the other side for the fuel source...
***Naturally, need to put a disclaimer that I shall not be held responsible and / or liable for your use of the information contained in my responses.***
