Old 12-16-2021, 12:04 AM   #62 (permalink)
freebeard
What it is is a Photochop. It's ambiguous whether the louvers are innies or outies.
I suspect the design is compromised because the louvers will face forward half the time and backward the other half. But it is the smoothest. Drill the backing plates. Drill the rotors.
Have you analyzed the panic stops? A good balance between brakes and tires is necessary. My notchback Type III with 145-15s in front ran out of tires before it ran out of brakes, downhill in the Coast Range.
JacobLeSann (12-16-2021)
