Old 12-21-2021, 04:28 PM   #11 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Autobahnschleicher View Post
You're not supposed to drive the car with the diesel/kerosene added to the oil.
Just a small amount of kerosene, similar to the so-called "priming" which used to be done on gasoline-powered piston-engined aircraft when radial engines outnumbered the opposed-piston engines.
