Old 12-26-2021, 09:24 AM   #5 (permalink)
Piotrsko
On most of the top loader washers I have repaired, the water pump is driven from the main motor under the drum. Seal failures are common but not enough to wet the floor. Had a Kenmore do this, found an impeller piece in the output pipe. Stupid machine did it twice before it got replaced.
