Old 12-28-2021, 11:45 AM   #635 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Nice to read some updates on this!
Vermont (right ?) to Metro Detroit? Condolences.
-I had an ABS light for the rear left ABS sensor, open circuit. Chased that fault all over the car until I found a bit of corrosion in a connector under the dash. ABS is working again.
I assume you had some kind of reader to tell you which sensor was reporting?
Currently the dash in Mirage #3 is lit up like a Christmas tree. Appropriate for the season, but the cause is, I think, a damaged wheel speed sensor wire.
The Mirage has more electronic driving nannies than the Insight did, so one bad wheel sensor = something like 5 lights on currently: ABS, brake, Traction Control, Stability Control x2.
-Looks like I'm going to need one brake line soon - also in the rear left. I have the materials, just hoping I can get away with leaving it be until after winter.
Is it actually weeping?
Reminds me of one time a few decades back my mechanic said I had a weeping brake line in my VW Rabbit. This was in the middle of winter. I said I'd look after it when the weather warmed up a bit. Didn't get the chance! A day or 2 later it popped, and I had to drive it back to the shop (my tail between my legs) using the parking brake & engine braking.
