Old 01-13-2022, 10:21 AM   #7 (permalink)
Piotrsko
Sounds typical for a 10-pack of LIons. 4.06 v is a lot less than what I charge the volt cells to, typically 4.15, can go to 4.2 or more if I don't care about longevity. Battery manufacturing specs call for full charge to empty which you didn't get to but you did do a typical. Wonder what the internal bms circuits tolerate?
If you went to 42v, you would derease your loss in WH but I dunno the effects otherwise to the cells. I do abuse my hobby cells and ryobi packs far more.
aerohead (01-13-2022)
