Originally Posted by Piotrsko
If you had the fuse, then you had the data plate with the Serial number which would give you a month year date using published data
Everything ahead of the firewall was gone, excepting the lower tunnel, with a few hard-points for engine attachment.
I would have kept the plate had I had it.
The N-number painted on the rear was incomplete, as part of the boom and all of the V-tail was gone also.
