Old 01-25-2022, 03:28 AM   #90 (permalink)
Xist
Are those links supposed to work?
One guy used steel wool and then clear coat, but not #0000, he used a Brillo pad, which is apparently what S.O.S pads are called overseas for no apparent reason.
I brought in my headlight after walking my brother. ChrisFix says that if you have moisture in your headlight, put it in a box with a hole and a piece of cardboard between the headlight and the hole, at least mostly close the box, and put a heat ray or hair dryer in the hole for 5 minutes.
I use a hair dryer on my glasses when we come back from our walk, so I wasn't too worried about the heat on plastic that has sat in the Arizona sun for up to 20 years.
Most of it quickly defrosted.
The rest looked like clear coat.
Do I bolt it to a 2x4 and scrub the edges again or skip to steel wool?
