Old 01-25-2022, 03:21 PM   #20 (permalink)
beate
HPV Tussie
vacuum bagging is way too complicated for my possibilities (no workspace, work either deep in the night in the garage or in my 1 room appartment).
The strength of glass is unfortunately not sufficient in this application. As the fork clearly shows. The only alternative might be a well thought construction of (european!!!) birch plywood, which has about half the strength of glass laminate but a third of the density, so a sufficiently strong construction will be more lightweight.
(The parameters of concern here are Young's modulus and density)
