Old 02-05-2022, 12:10 PM   #5 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Yes. The smaller the volume behind the throttle plate, the smaller the pumping losses (as I understand it). ITBs are an improvement, but you still want some kind of plenum with a single opening, and you'll want to use mass airflow to meter air, because a MAP-based system typically doesn't work well with ITBs.
Even better than ITBs is moving the "throttle" right to the valves. Honda's R series engines (2006+ Civic) vary the intake cam to control valve opening and therefore throttling, under some conditions. It still has a throttle plate, but that gets held wide open when it changes to variable valve timing throttling. Honda claimed a 16% reduction in pumping losses over their standard VTEC system.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
aerohead (02-07-2022), freebeard (02-05-2022)
