Originally Posted by cfg83
In the 2008/10/08 test, I wasn't being smart and did some strategic EOC, so I am sure that it contributed to the higher % (when you turn the key to the off position, the car odometer stops, but the GPS keeps right on chugging).
Kudos on your accuracy!
I really need to do this
So the Odometer quits when the key is out? Weird -- I didn't know that some cars did this. It makes sense if the intention is to tow the car behind a motorhome as many Saturns are designed to do.
RH77
