Old 02-18-2022, 05:58 PM   #5 (permalink)
aerohead
Energi
So I have noticed 2015-2018 Ford Fusion Energi PHEVs have dropped under $20,000 with 50-100k miles on them. Even down to $15,000. Are these reliable? They only show a 22 mile EV range but otherwise get over 40mpg. I currently have a 2017 Lincoln version, non hybrid, so I like the ride, size, features, looks. Thinking about dropping a car payment and trading the Lincoln for a PHEV hybrid version. I lose AWD and 400hp but that's only so fun for a few seconds.
AeroStealth had one. It was his gateway drug into BEVs.
He had one electronic issue which Ford took care of at no cost.
I remember around 34-mpg in steady, constant-speed interstate at around 65-mph with A/C on.
If your normal commute is around 22-miles, you've essentially got an EV.
The engine will start periodically just to exercise the engine and burn a little fuel. Like a Volt. A tank of gas can last a long time.
The heated seats save some battery capacity during cold spells. Something he wishes his BOLT had.
Hersbird (02-18-2022)
