Old 03-03-2022, 03:08 AM   #15 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by assistance View Post
thinking of buying a $250 dollar scuba compressor (4500psi) on amazon to compress CNG for cars.
The CNG stations charge 1.60 / GGE, and homefill would be 30 cents per GGE.
The plan would be to have a flash back arrester on the intake to the compressor to prevent any accidents from going back into the main line.
Might also have a check valve to make sure the gas only goes one way.
It would appear impossible to have a flashback arrestor on the tank line due to 4500psi.
I havent been able to source cng service nozzles, i found fill ones but not the service handles like at the station, so i will be using a diy connector system that is rated for 4500psi, probably ball valves instead.
What u think of the plan?
dude it's going to take a LONG time to fill using a home gas pipe it's better to just use the station they use High pressure gas lines
the house pipe is 10psi that is at the tap
after the meter & regulator it's down to 1psi 7-10 hours fill time... if you had 10 psi at the stove the flame would be 10x bigger
source: talked to the gas man before
