Old 03-23-2022, 02:39 AM   #2 (permalink)
oil pan 4
We can calculate that out.
If you only have to heat the water 60 degrees that's 510 btu per gallon. 20lb of propane should heat nearly 600 gallons of hot water per 20lb tank at 75% efficiency.
I'm a bit of a propane pro. Don't use 20lb tanks. It typically costs around $20 to fill a 20lb tank, but it will usually cost around $30 to fill a 40lb tank. But a 40lb tank weights over 80lb when full.
