Old 03-23-2022, 03:42 AM   #8 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by Gasoline Fumes View Post
Fuel log says high teens. EPA estimates are about 20 MPG.
that is city mileage 100% our speed limits are 45-60mph Yes that does a number on the mpg stopping and going...
Also I think the v4 disable chip is causing issues unless I plug it in after putting it in drive gear...
when i started plug it in after putting it in drive the mpg went up slightly
the best I was able to do was 31.3mpg at 38mph 100% v8 mode on a 33miles round trip (Yes same pump)... that was with Perfect weather conditions i.e no wind...
It's always windy, you can tell when it gets 15mpg it's really windy
I have to swap out the O2 sensor I suspect it has a faulty one on bank2 sensor 1.... since it's slow to respond after a DFCO (deceleration fuel cutoff)
it reads ZERO (0.00v)on my OBD reader(while sensor 2 will show 0.160 for example) and slowly changes when i start going again (unless give it a good amount of throttle ) i had gotten P0420/p0430 in the past( faulty barometer sensor )
there will be random spikes with the o2 sensor readings in a DFCO event
This suv has aggressive DFCO no engine braking.(unless it's in 4 speed mode which has aggressive engine braking )
