Old 04-01-2022, 10:50 AM   #451 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
The 125cc Suzukis I'm familiar with have only a 5-speed gearbox. But for that dual-purpose model, sure having an extra gear makes it easier to set it up for general usage despite its aerodynamic disadvantage on highway. Well, maybe it also being subjected to lesser emission regulations than a more recent model with a similar engine leaves a more reasonable power and torque reserve.
Pretty much. The newer dr200 uses the carb they swapped to in the 90s and the dr125 from the 90s also uses the same carb. Looking at swapping to the I think 31mm carb off one of those from the 26mm carb that comes on this one. Supposedly nets me 14hp from the 12hp these come with. Newer DR200 is still grandfathered into whatever year it made its last change to the model. Judging by the looks its probably still grandfathered in around 1992.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
