Old 04-01-2022, 01:42 PM   #15 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Here’s the Aerocivic data from the Speed vs. MPG charts thread. These are the results that you need to match or exceed as you restore and further mod the Aerocivic.
QUOTE=basjoos;427984]I finally got out and did a series of steady state speed vs. mpg runs in the Aerocivic. Finding a sufficiently level road was a search (this region is called the Piedmont for good reason), but I found a 6 mile stretch of highway that paralleled a railroad right of way that was very level and had only a 53 foot height variation along the 6 mile stretch. Elevation of test road was 700 feet above sea level
Air temperature at time of test 91 degrees F.
2 runs in each direction at each speed. Remained in lean burn at all speeds tested.
50 mph 95mpg
55mph 87mpg
65mph 77mpg
70mph 71mpg
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
MeteorGray (04-02-2022)
