Is there a red or blue air bag inside the coil spring? What's #18?
With coil springs the options are to cut the coil or use a spring compressor to strap two coils together.
The sequoia comes with 2 different suspensions. It looks like you found the more complicated one with airbags. Mine is much more simple than that. I could possibly cut the springs, but only if they are the right kind to cut. Straps are out of the question for me.
