Old 04-02-2022, 11:41 PM   #1 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Suspension question
I want to lower my 2008 Sequoia to increase mpg and handling, but I have not been able to find any lowering kits specifically for the Sequoia. There are some kits out there for the Tundra though (they have the same front end as the Sequoia). Will only lowering the front end by 2" yield similar benefits to lowering both front and rear?
Old 04-02-2022, 11:53 PM   #2 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Are you trying to avoid lowering the rear?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 04-03-2022, 12:02 AM   #3 (permalink)
I would like to lower both front and rear. There are no kits I can buy to lower the rear of the Sequoia. I would have to use a Tundra set for the front. So I want to know if lowering the front only would still be worth it.
Old 04-03-2022, 01:53 PM   #4 (permalink)
dz310nzuyimx0.cloudfront.net/strapr1/74c1414c76b621ca5bc09eb16c0073fd/6bf14d98ed1931baf18b5d5f30fc2653.png
Is there a red or blue air bag inside the coil spring? What's #18?
With coil springs the options are to cut the coil or use a spring compressor to strap two coils together.
Old 04-03-2022, 02:32 PM   #5 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
You'll have to define "worth it"; that varies from person to person. You should also define your goals: what, specifically, do you want to change aerodynamically or in the handling?
Then you need to gather some data. Are the lowering springs for the front stiffer than the stock springs? How will that change the balance with the stock rear springs? What are the natural frequencies of your suspension, front and rear, now? You can find out very easily with just your smartphone:
Will lowering your vehicle decrease drag? Will it decrease drag enough to show up as an improvement in fuel economy? Unfortunately this is harder to answer, as you can't really test ride heights without an adjustable (air) suspension. Based on everything I've read (which is a lot), cars usually show a drag decrease with lowering but not always; there's no guarantee yours will, and none of us here can say one way or the other.
For what it's worth, if I was starting out with a new car or SUV I wouldn't bother lowering it unless I was changing the suspension for some other reason. But if you do, an interesting experiment might be to identify a 200 mile or so freeway loop, run it and record fuel economy; immediately swap the springs and then fill up and run the same loop again at the same speed. If there's a difference in drag it might show up in a test like that.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
freebeard (04-03-2022), Taylor95 (04-03-2022)
Old 04-03-2022, 04:05 PM   #6 (permalink)
The sequoia comes with 2 different suspensions. It looks like you found the more complicated one with airbags. Mine is much more simple than that. I could possibly cut the springs, but only if they are the right kind to cut. Straps are out of the question for me.
Old 04-03-2022, 04:08 PM   #7 (permalink)
Very interesting video. One of the main reasons I want to lower the car is to improve handling. The sequoia has quite a lot of body roll. Improving mpg would be nice too; some here have claimed a 5% mpg gain after lowering their car.
Old 04-03-2022, 05:00 PM   #8 (permalink)
Establish the front and rear roll center heights. The line from front to back wants to be level.
hayden55 (04-04-2022)
Old 04-03-2022, 07:03 PM   #9 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
What is the stock sway bar setup? Adding a rear or upgrading to a stiffer bar could get you what you are wanting. That's what people do for Astros anyway. Should be similar weight distribution. I haven't put my rear bar on yet, but the stiffer front makes it handle a lot different.
1995 Mercury Tracer
Old 04-04-2022, 12:18 AM   #10 (permalink)
Adding a rear sway bar is something that would definitely improve handling. I believe Toyota makes a TRD rear sway bar for the Sequoia that works well.
I will probably still try to figure out a way to lower the Sequoia for additional handling and possible FE benefits.
It is a pretty tall vehicle that I have no intention to take off road ever. I don't really need all the ground clearance it has.
