Thread: Steam power...
Old 04-04-2022, 12:35 PM   #43 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
The CEL is on or it's not and leaves a record in memory unless hard reset. You had a lazy/cheap dealer issue which is not surprising. Based on your reply, it wasn't worth escalating to the mothership. We'll see what happens when my cheap wife's neglect causes issues with ours.
This problem has never thrown a code or turned on the CEL.
From a stop under moderate to hard acceleration the car will accelerate normally just enough to get you out in traffic. Then it bogs down almost like it goes into limp mode. After about 1 second it clears out and accelerates hard again - sometimes spinning the tires. It happens a couple times a month - no set pattern.
