Old 04-04-2022, 07:48 PM   #768 (permalink)
freebeard
1) Excuse me.
4) DDG/?q=Montessori+method+text+structure does not offer a clue. Citation?
5) I'm reminded of computer code line numbering
8-9) this is sufficient and less verbose
2) If you want to participate, discuss the topic at hand.
Like this?
non-factual
Illogical
Incoherent
irrational
underinformed?
misinformed?
lied to?
duped?
If you want to argue science, you might want to argue the science.
If climate science is 'wrong', then electricity is wrong.
The existence of a FLUKE VOM is a myth.
Amprobe clamp-on ammeters are a fiction.
Ohms Law is just psychobabel.
Right hand rule never existed.
Motors and wiring should be operated at 180-C.
DC should always be directly connected to AC. What difference does it make?
Electromagnetism is just a leftist, liberal, communist hoax.
If flux-core solder existed, you'd want to inhale all its vapors.
Forget oscilloscopes, they never existed.
Shottky barrier diodes can look kinda like transistors, just use them interchangeably!
Heat sinks? Heat is a hoax!
Don't direct an infrared pyrometer towards an overheating transformer.
Transformers! As if they actually had primary and secondary windings inside.
There's no such thing as infrared radiation.
There's no such thing as temperature.
Any talk of overheating is just scare-mongering
Always wire 3-phase motors to single-phase sources.
60-Hertz? Why not 600? What's in a number? Cycles don't exists.
High-tension lines? Why waste money on expensive ceramic insulators?
They don't make any difference. Everyone and their dog knows that.
Ground fault circuit interrupters? You've got to be kidding!
Fuses? They're for sissies!
Circuit-breakers ? You've got to be nuts!
Insulated wiring. Like that would help.
Wave-soldering? Sure. Cowabunga dude!
Utility sub-stations. Just a waiting children's jungle-jim.
Sizing conductors for ampacity. You're kidding, right?
Like DC voltage drop was a thing.
