Old 04-11-2022, 06:32 AM   #65 (permalink)
alexshock
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 40.85 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 30.42 mpg (US)
Originally Posted by Drifter View Post
Hope you're doing okay
SNAFU
Any issues with heat from the catalytic converter?
Unfortunately, project is now going much slower than it was planned - I have not yet complete installation, this is just a mock up.
What you see on images above is just a front part that is exactly stops before catalytic converter. So, there should be no heat issues. I'm planning to cut it from plywood - if everything will be fine, I'll replace with some sort of composite (GFRP).
The rear part is not yet ready, but I'm planning to create 2 separate parts for the left and right side. What about catalytic converter and pipes - it will remain open. Probably, it could be covered with aluminum plate with some naca-ducts for ventilation, but I will test carefully before.
The Following User Says Thank You to alexshock For This Useful Post:
Drifter (04-11-2022)
