03-10-2022, 01:02 PM
#61 (permalink)
The price has reached an historic high, but people should be most concerned about fertilizer and wheat.
Yes, true)) wheat will be a realy big concern. I had not mentioned it here because the focus of this forum is fuel
I have just visited the pump:
Price is $1.54/L, (95) while it was $1.26/L before the war.
Also, now we have a limit of 20L per one person at a time. It is risky to benefit from driving with almost empty tank
The Following User Says Thank You to alexshock For This Useful Post:
03-10-2022, 01:07 PM
#62 (permalink)
Originally Posted by aerohead
1) I left my workbook at home, but I believe that for the New European Driving Cycle, a 10% change in weight equates to approximately 1.5% change in fuel economy.
2) In the USA, EPA fuel economy testing is done with 300-pounds ( 136-kg ) added to the vehicle.
3) The Auris is reported with a curb weight from 1190-kg, to 1480-kg.
4) So a 10% weight reduction would be 119-kg, to 148-kg, to see a 1.5% difference.
5) Or 79.33-kg, to 98.66-kg to see a 1% change.
My Auris is a hybrid - the heavies one, 1480 kg.
It does not work IRL. I have a clear pattern of driving alone and with my wife. The difference is 0.5L/100km in the city - this is about 10%. (May be due to hilly terrain.)
(There is no difference on the highway.)
03-11-2022, 12:42 AM
#63 (permalink)
Maybe if you could ride a small-displacement motorcycle it would be easier to overcome this issue, assuming you won't be able to mod your Auris to the point it would have the same fuel consumption of a Honda CB 125 or Yamaha YS 125.
04-10-2022, 11:20 PM
#64 (permalink)
Cx9 - '18 Mazda CX9 Grand Touring 90 day: 31.41 mpg (US) Prius - '10 Toyota Prius III 90 day: 57.8 mpg (US) Tundra - '00 Tundra V6 long bed base work truck 90 day: 19.4 mpg (US)
Hope you're doing okay
2. Did fitment check with PVC model. It is almost perfect. Created holes for factory fasteners.
3. Put OEM plastic undertray until I will build custom one.
Any issues with heat from the catalytic converter?
04-11-2022, 07:32 AM
#65 (permalink)
SNAFU
Unfortunately, project is now going much slower than it was planned - I have not yet complete installation, this is just a mock up.
What you see on images above is just a front part that is exactly stops before catalytic converter. So, there should be no heat issues. I'm planning to cut it from plywood - if everything will be fine, I'll replace with some sort of composite (GFRP).
The rear part is not yet ready, but I'm planning to create 2 separate parts for the left and right side. What about catalytic converter and pipes - it will remain open. Probably, it could be covered with aluminum plate with some naca-ducts for ventilation, but I will test carefully before.
04-12-2022, 01:17 AM
#66 (permalink)
Maybe it would be worth to use plywood and not switching to GFRP. IIRC plywood had been widely used for making underbody protections for rally vehicles.
04-12-2022, 04:07 AM
#67 (permalink)
Aluminum skinned thermoplastic sheet.
Back in my day there was so much toilet paper and eggs that we would throw them at the houses of our enemies
05-08-2022, 10:55 AM
#68 (permalink)
Antenna Segment #2
Replaced shark-fin antenna with a small block-off.
Now I cannot listen to FM/AM radio, but I don't care.
OEM fin weight is 238 g.
Block-off weight is only 8 g.
I have removed only 1 out of 3 antenna cable parts, so there will be more work.
Block-off is taken from US/MEX WV Jetta. It perfectly fits into Toyota's roof-hole.
One more segment removed with additional reduction of 79 g
Before / After:
05-08-2022, 10:57 AM
#69 (permalink)
Roof Antenna (Block Off)
BTW, final result on the roof looks pretty good:
05-22-2022, 12:45 PM
#70 (permalink)
Final segment: -60g.
