Old 04-12-2022, 10:36 AM   #34 (permalink)
Piotrsko
The app is just reading sensor data from the bus. It is as accurate as those sensors are, BUT you can apply external translation formulae in the PID. You could define fuel flow as volts if you wished.
CALI required the injectors to not fire on engine on coast in 2000 and apparently everyone copied that for 50 state compliance
