Thread: Side Mirrors...
Old 04-16-2022, 06:10 PM   #11 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by Phase View Post
I've seen that video. im not even thinking about using smaller car mirror. i was actually going to stick a screw out and then attach one of these super mini 3 inch blind spot mirrors. and then id fabricate some type of little aero cover shell on the backside of it facing the wind.
That's fine--but if you want to know if the smaller blindspot mirror (with or without fairing) has lower drag than the stock mirror, you will need to test it. There's an unfortunate belief on this forum that you can assess the aerodynamics of an object or shape simply by looking at it when this is not true, especially when it comes to small add-ons subject to interference drag in areas with complicated flow patterns such as mirrors. (You'll find statements to this effect in any textbook on aerodynamics; I know because I've read a lot of them! You can--and should--too).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Drifter (04-16-2022)
