Old 04-18-2022, 04:40 PM   #153 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
I'm hoarding two dishes. Once I figure out how to roll the flanged edge appropriately halving one would suit the XFi. If you're rolling by on I-5 we might agree on a neutral location.
They may be small, at most a half-skirt, but they're rigid.
I have some fiberglass skirts for the Superbeetle, but they're Foxcraft reproductions and I think they're too flat. I was going to use a Dish antenna for a mold and make curved caps to re-contour them.
The plan so far is to start with a curved tube with flattened ends that fit into fixtures at the front and back. Drop in at an angle and turn upright to lock it in, then a single locking tab at the top. Probably from a Type II gas door with the churchkey.
im up and down i5 on the regular. from portland to seattle to eugene and roseburg
so far it seems like aluminum with the bent/curved carbon arrows inside seems to be the easiest
https://youtu.be/_ww5TIOPNy4
this guy did some for his prius in seattle/tacoma but bolted on the outside frame of the body. ideally id like to figure out inserting into the edge of the wheel wells to have a cleaner OEM look without screws sticking out
The Following User Says Thank You to Phase For This Useful Post:
aerohead (04-18-2022)
