Old 04-21-2022, 01:59 PM   #5 (permalink)
aerohead
window tint
Originally Posted by Phase View Post
So random question, and had no idea where to post this but…
I’ve seen some window tinting companies also make claims that their window tints also keep the car warmer in the winter because INFRARED RAYS Go both ways. So the heat it blocks out from the sun coming in isn’t the only thing the tints do. It also blocks the IR from going out of the car also. I’ve seen some people simply claim that window tints are insulation.
This kind of makes sense, but is it backed up at all? Have any tests been done? Will a car that has window tints stay warmer longer in the cold winter?
PhD Richard Feynman claimed that simple window pane would prevent UV radiation from passing.
Visible spectrum radiation would pass through, then change to long-wave infrared as soon as it touched a surface, and get trapped inside the 'greenhouse.'
Selective coatings on films could be tailored to particular wavelengths, as far as 'radiative forcing' goes.
They could do NOTHING as far as 'conductive heat-gain, or 'heat-loss' were concerned.
Sitting close to the glass, you might not 'feel' your body chilled or heated so much, but the R-Factor ( or it's inverse, heat-transfer coefficient ) of the cabin would be whatever it was.
At some point you need 'insulation.'
