Is that two pictures of one thing or two things? Different models for the 2-door and 4-door?
In any case the exemplar is Aerocivic -- two parallel walls. The constraint is the breakover angle.
A possible solution would be solid spats at the front and rear with a tension cable at the bottom of a [semi-]flexible skit.
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..The quickest way to double your money is to fold it iin half and put it in your back pocket -- Will Rogers
