Old 05-06-2022, 02:45 PM   #236 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Is that two pictures of one thing or two things? Different models for the 2-door and 4-door?
In any case the exemplar is Aerocivic -- two parallel walls. The constraint is the breakover angle.
A possible solution would be solid spats at the front and rear with a tension cable at the bottom of a [semi-]flexible skit.
I think it’s the same skirt just on different cars. It slightly lowers it but it looks like the angle sticking out keeps some side air from going under near the body, and the rear little thing at the end of the skirt looks like it would direct air up only the rear wheel skirt when I make it
The Following User Says Thank You to Phase For This Useful Post:
freebeard (05-06-2022)
