Old 05-09-2022, 12:55 PM   #443 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
This pic was from last week when my intake fuel pump shut off due to a negative factory pin in the plug corroding and not making a good connection.
Boost 27 psi, RPM 3205, A/F 16.1 total time before it went off the WB scale was .5 seconds basically fuel cut lol
I got luck again after I fixed it I did some testing to check the engines health "leak down, comp test and my crank case pressure data-log on a 33 psi run". Everything is good.
So now I think my spray guided piston design is working and controlling detonation by keeping the flame kernel at the center of the piston even when it auto ignites?
Pressure Gradient Force
The Positive Side of the Number Line
