Originally Posted by JSH
Nope won't work. A box fan barely develops any pressure differential, it works great with cheap filter that you can see through to pull big chunky dust out of the air. But put a merv13 on there and nearly no air moves. I use 2 bathroom fans to pull through 24x24 merv16 filters, the bathroom fans pull air through those filter like they aren't even there.
https://www.survivalmonkey.com/threa...2-and-3.68563/
The most difficult part about building your own home air filter is knowing that a box fan can't pull hardly any air through a number 13 or higher filter.
