Addressing aerodynamics of a big box? there could be some improvements, but not many. Been looking for a stream here that could be scaled up from a van.
Like this?
https://www.dfrc.nasa.gov/Gallery/Ph...uck/index.html
I know aerohead has analyzed this in the past, here is one specific thread. ecomodder.com/forum/showthread.php/plan-my-cargo-trailer-30395.html#post453403
Long story short, the brick is the same on the underside. I posted about my design for a semi-rigid boat tail after you posted about the Trucksack in 2020.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
