Thread: Prius 75-91mpg
Old 05-17-2022, 02:19 AM   #258 (permalink)
Nathan jones
Ecomodding Apprentice
Finally done. I will replace the rear joint with titanium I have spare, not a very good design. The spacer gap I used cf and cyanoacrylate then sanded, it's been up steep hills and fine so far. Alot quieter and around 2800g less
That's A weighted db
Also I filed the spacer so the titanium I had to heat up to fit, then it only needs a light worm clip
ID:	32152   Click image for larger version
ID:	32153   Click image for larger version
ID:	32154   Click image for larger version
ID:	32155   Click image for larger version
ID:	32157   Click image for larger version
ID:	32158   Click image for larger version
ID:	32159   Click image for larger version
ID:	32160   Click image for larger version
