Old 05-09-2022, 02:03 PM   #251 (permalink)
Ecomodding Apprentice
The second car has the original wheels, missing trim, and a new single one is 51, I can make cf ones for less
A set for less
ID:	32088   Click image for larger version
Old 05-09-2022, 02:29 PM   #252 (permalink)
More trestle and car parts. The inverter bracket has been on since yesterday and have been on lots of bumps and it's not broke so all good. I made it extra strong since the steel one was around 6mm but the inverter only weighed about 10-15kg shared between 3 or 4 brackets so I could have made it lighter. Mostly carbon with dress aramid, although a bit ropey and rough, also not quite cured...the engine heat will sort that
The straight bar is from the trestle. Another much longer one to do and quite tricky. The molds done and half laid up but no pics yet, I added some directional fibers too
ID:	32090   Click image for larger version
ID:	32092   Click image for larger version
ID:	32093   Click image for larger version
ID:	32094   Click image for larger version
ID:	32096   Click image for larger version
Old 05-09-2022, 02:36 PM   #253 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 40.85 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 30.42 mpg (US)
Originally Posted by Nathan jones View Post
Making more trestle parts
Nice new wheels on your Prius
Old 05-09-2022, 02:40 PM   #254 (permalink)
So as I was told getting rid of my backbox would ruin my mpg, yes I found out it was true but this titanium will replace my centre box/resonator. I will test the spl before and after also as well as mpg. It took one hour and 15 minutes to saw through with the carbide hacksaw, it's hard work. Just the slots to do unless I make sleeves and use stainless rivets, I will post soon..
ID:	32098   Click image for larger version
ID:	32099   Click image for larger version
ID:	32100   Click image for larger version
ID:	32101   Click image for larger version
Old 05-09-2022, 02:53 PM   #255 (permalink)
alexshock's Avatar
What is the final configuration?
So, you will keep stock back box (muffler?), but the pipe will be from titanium, and center box (is that resonator or catalytic converter?) will be replaced with raw titanium pipe?
Old 05-09-2022, 04:13 PM   #256 (permalink)
What do you think of this?
www.youtube.com/results?search_query=forged+carbon+fiber
How Strong is Forged Carbon Fibre? Forged Carbon vs Aluminium vs Markforged vs Onyx
The tensile test shows the catastrophic failure mode. Optimized forged carbon fiber sounds like the winner.
Old 05-10-2022, 12:08 AM   #257 (permalink)
Making rear bumper mold. I think 150gsm outer skin and 60 inner styrene sandwich panel
I will make a white gelcoat or it will take too much paint
ID:	32105   Click image for larger version
Old 05-17-2022, 01:19 AM   #258 (permalink)
Finally done. I will replace the rear joint with titanium I have spare, not a very good design. The spacer gap I used cf and cyanoacrylate then sanded, it's been up steep hills and fine so far. Alot quieter and around 2800g less
That's A weighted db
Also I filed the spacer so the titanium I had to heat up to fit, then it only needs a light worm clip
ID:	32152   Click image for larger version
ID:	32153   Click image for larger version
ID:	32154   Click image for larger version
ID:	32155   Click image for larger version
ID:	32157   Click image for larger version
ID:	32158   Click image for larger version
ID:	32159   Click image for larger version
ID:	32160   Click image for larger version
Old 05-26-2022, 05:18 PM   #259 (permalink)
Its not letting me post pictures...
Old 05-26-2022, 05:25 PM   #260 (permalink)
It seems to be going around. Have you tried another browser?
