Old 05-23-2022, 03:40 PM   #499 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by Rcnesneg View Post
Been there done that also.
300 miles at 80°F turns into 280 miles at 10°F on snow tires. Modern EVs with good insulation and a heat pump aren't affected by winter as much as a gen 1 leaf. Snow tires are the biggest hit due to the extra drag.
My Leaf had a heat pump. But at temperuatures down to -40°F it doesn't use it. Not that I'm expecting a miracle, but this is why I want a lot of range, so the winter range isn't too little. Either that, or I need a cheap beater EV that's good for around town only.
I don't want to spend $40,000 or even $10,000 or even $5,000 on a car that I can only use around town when I can pick up a beater ICEV that would work fine for that same purpose for under $1,000.
