Thread: Global Cooling
Old 05-26-2022, 04:08 PM   #33 (permalink)
aerohead
comment... heliosphere... meditate
How does your comment move the discussion forward.
Heliosphere, Ionosphere, Thermosphere, Mesosphere. Stratosphere, Lithosphere, Mantle.
Meditate on this:
https://nasaviz.gsfc.nasa.gov/4641
NASA have moved beyond your Crystal Spheres weltanschauung. I highly recommend the video at #25. It starts with Plato. And gets you to co-axial filaments without any cable.
1) The question is quite straightforward. There's a reason why you're using ESA data. I'd like to know why you use it.
2) The question about the heliosphere is also quite straightforward. Are you ever going to give me a simple answer?
3) Of all the 'spheres' you mention, the troposphere has been omitted. It's the only 'sphere' which is germane to the topic of global cooling. Why do you intentionally deflect the conversation away from the only thing associated with the subject.
4) And add to it, as if we haven't moved away from the subject far enough already.
5) If you want to discuss failed philosophers you could start your own dedicated thread.
