Old 06-14-2022, 09:18 AM   #445 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Update:
Finished Pre-Chamber v3.
This newer version has a much better flame torch then the last two versions. This will help with flame speed during my ultra-lean burn.
Also seeing lower spark plug temps and head coolant temps. This was a major win for me for the way I design my pre-chamber, it needs to run much cooler than other pre-chambers for fuel collection.
Also did some GEM31 fuel testing with the v3 and it runs great. This fuel comes out to around $4.40 a gallon. So, the next test is to see what the fuel mileage is compared to E10 gasoline. My math and homemade gas generator say it will be around 31 mpg Freeway.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Ecky (06-14-2022)
