Old 06-16-2022, 10:17 AM   #4 (permalink)
IRONICK
IRONICK's Avatar
I used high density polyethylene. Black color, UV resistant. It's easy to work with and nor does it break from stones etc
With a thickness of 3mm or 4mm, depending on needs. The material can be cut even with a simple cutter
The Following User Says Thank You to IRONICK For This Useful Post:
aerohead (06-16-2022)
