Old 06-12-2022, 09:33 PM   #1 (permalink)
How do you join(fasten) your belly pan materials?
I am mocking up the van belly pan with cardboard and hope to begin the real thing in about a month. I see that pop riveted screw nuts can help fasten materials to the frame/body, but how about fastening the belly pan material to other sheets of belly pan material? I need to make access ports for oil changes and greasing the front end so I need easily dismantled and reassembled joints.
The belly pan will be attached to the back bottom of the ABS air dam and then go back 4 to 7 feet.
I have some large sheets of coroplast that I can use if they are resilent enough to take some impact damage and then return back to shape. Otherwise I will need to get a sheet of ABS plastic... any recommendations for thickness?
I have a section of exhaust that I may cover and was thinking of using 1/4 inch hardware cloth. High speed air moving parallel to the clothe will most likely see a solid surface. However, while driving slow, low speed air can still circulate freely to cool the piping. Anyone with experience with this technique?
The Following User Says Thank You to EcoVan For This Useful Post:
aerohead (06-13-2022)
Old 06-12-2022, 11:54 PM   #2 (permalink)
Polymetal or equivalent.
Something like ABS (some thermoplastic) with aluminum skins as thick as a soda can, with baked enamel finish.
It's as rigid as 5/8th" plywood, maybe twice as expensive, but it's prefinished. It would last much longer than Corplast, ABS or plywood.
Rather than hardware cloth, consider perforated metal.
Old 06-13-2022, 11:05 AM   #3 (permalink)
fastening
[QUOTE=EcoVan;669500]I am mocking up the van belly pan with cardboard and hope to begin the real thing in about a month. I see that pop riveted screw nuts can help fasten materials to the frame/body, but how about fastening the belly pan material to other sheets of belly pan material? I need to make access ports for oil changes and greasing the front end so I need easily dismantled and reassembled joints.
One can make the access opening a little oversized.
If clearance above the panel allows it, attach angle aluminum, with a wide enough 'fin', all around the perimeter of the opening, such that from below, enough of that 'fin' projects into the opening, to allow attachment of the access panel.
The 'fin' can be pre-drilled, with speed-nuts attached to receive fasteners from below. Dzus fasteners.
If you are 'lifting' the vehicle for servicing, or have a 'pit', one side can be hinged, as on aircraft access panels.
Pop-rivets are okay for permanent attachments if they're installed with flat washers, to spread the load out over the coroplast.( Al just gave me 10-sheets of 18" by 24" of real estate sign coroplast for free ).:
Old 06-16-2022, 09:17 AM   #4 (permalink)
IRONICK's Avatar
I used high density polyethylene. Black color, UV resistant. It's easy to work with and nor does it break from stones etc
With a thickness of 3mm or 4mm, depending on needs. The material can be cut even with a simple cutter
The Following User Says Thank You to IRONICK For This Useful Post:
aerohead (06-16-2022)
Old 06-16-2022, 01:27 PM   #5 (permalink)
Eventually the belly pan on my leaf is going to get shredded or get lost. I will remake it with 1/8'' mild steel diamond tread fastened with 1/4-20 bolts to flange nuts welded in the original belly pan trim fastener holes.
Old 06-18-2022, 10:23 AM   #6 (permalink)
Cast diamond plate or punched? Can't see punched helping in any orientation
