Old 06-16-2022, 06:35 PM   #3 (permalink)
XCRN
Originally Posted by M_a_t_t View Post
Did you mention the average speed of 35.87 because that's all you have to work with?
I see your thinking, but I don't think that would be a very accurate way of calculating it.
I got all sorts of values I can use. I converted the data log to a excel spread sheet and there is about 40,000 lines of data that are roughly at 0.024 seconds per point. I attached pics of the different data points that are possible if setup. The Fuel Economy data point does not work on mine because it requires an electric GM trans that I do not have.
ID:	32382   Click image for larger version
