Old 06-16-2022, 06:13 PM   #1 (permalink)
Alternative MPG Calculation
I just wanted to verify my thinking and math with the tools I have. I run a Holley Terminator X and I can take logs of short trips and sections of drives. In the logs I can see my overall fuel flow in lb/hr and speed in MPH. I setup a spread sheet of a log of my daily commute to work and the average speed was 35.87 mph and found the average fuel flow to be 12.75 lb/hr for the whole trip. My question is the formula based on these values. I have been using this formula.
Code:
(speed)/(fuel flow)*(weight of gas/gallon)
My understanding is a gallon of gas is 6.3lbs. In the above case I got 17.44mpg but at the pump doing the tradition calculation I have been multiplying the miles by 1.09. I have comparred the Jeep ODO to a GPS and the GPS reads higher by about 9%. So when I multiply the speed by 1.09 and do the calculation again, I get just over 19mpg.
Does my barely passed highschool math check out or am I wrong? I have been making some lean tunes and so far the best I have gotten was 16mpg for the last 2 tanks using a corrected speed and 13mpg before that, so I am a bit skeptical I did this good.
The Following User Says Thank You to XCRN For This Useful Post:
aerohead (06-23-2022)
Old 06-16-2022, 06:25 PM   #2 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Did you mention the average speed of 35.87 because that's all you have to work with?
I see your thinking, but I don't think that would be a very accurate way of calculating it.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 06-16-2022, 06:35 PM   #3 (permalink)
I got all sorts of values I can use. I converted the data log to a excel spread sheet and there is about 40,000 lines of data that are roughly at 0.024 seconds per point. I attached pics of the different data points that are possible if setup. The Fuel Economy data point does not work on mine because it requires an electric GM trans that I do not have.
ID:	32382   Click image for larger version
Old 06-16-2022, 07:06 PM   #4 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
If you have it plot each point as a mpg number (instant speed / instant fuel rate) then average that it would be accurate, but probably the wrong units. It might be easier to have excel convert it to gallons/hr then plot it
I thought maybe all you had were averages, which wouldn't necessarily give the whole picture.
*I didn't look at your pictures since I am on my phone. I will when I get home though In case I missed something.
1995 Mercury Tracer
Old 06-16-2022, 07:18 PM   #5 (permalink)
The only fuel flow I can get is in lb/hr. So how could I convert that to gal/hr?
Old 06-16-2022, 07:45 PM   #6 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Divide by 6.3 (or whatever the weight of gas plus % ethanol is).
1995 Mercury Tracer
Old 06-16-2022, 07:51 PM   #7 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
If you only wanted the average for the trip/data recorded same you probably could have used the averages. Just use the average flow rate and average speed and the overall time to calculate total. So if you averaged 35.87 mph for one hour and 12.75 lb/hr (2.023 gal/hr) then you would get the average for the data. Which would be 17.7 mpg
Sorry, I just realized that after re reading everything.
If you do it the other way you would be able to see how your fuel economy was fluctuating and with some more math you could tell when and where you were getting the best fuel economy
1995 Mercury Tracer
Old 06-16-2022, 08:04 PM   #8 (permalink)
Its been nice having these numbers since I can setup certain inputs to offset target AFR or ignition timing by flipping switches and I can see what has the best effect on fuel economy and just use averages of certain points instead of the whole log.
Old 06-18-2022, 04:19 AM   #9 (permalink)
Cx9 - '18 Mazda CX9 Grand Touring
90 day: 31.41 mpg (US)
Prius - '10 Toyota Prius III
90 day: 57.8 mpg (US)
Tundra - '00 Tundra V6 long bed base work truck
90 day: 19.4 mpg (US)
Does your car return fuel to tank or is it returnless? If it returns fuel, does your fuel flow calculation account for that?
Old 06-18-2022, 08:21 AM   #10 (permalink)
It is a return, and I am not sure how it calculated flow, but my guess is it takes a calculation based off of the fuel injector flow specs that had to be entered in manually or pick a preset factory injector part number, the fuel pressure, and the duty cycle of the injector. Mine is a return system with a regulator roughly 12” from the tank.
