Old 06-21-2022, 10:25 PM   #69 (permalink)
freebeard
connecting the "corners" would be a creation... almost artsy.
Four quadrilateral flaps and the corners filled with cone-shaped inflatables?
https://i.pinimg.com/originals/88/2e...73ada468a4.jpg
IIRC, fineness ratio is for the compound curve Template. With torpedoes or truck vans, once you exceed a length where the disruptions at the front have found reattachment, it's all the same. See Mair.
If your d is 7-8ft, a 36" box cavity would be minimal.
aerohead (06-23-2022), sregord (06-21-2022)
