Phase -- It's hard [for me] to tell, is the stalk just a piece of all-thread? Can you adjust it?
I can imagine adding the sculpted foam former, then vacuum-forming a shell over it. Instead of removing it, just trim the edge. If there is an undercut, it would act like a crimped edge.
its a giant screw and then abs plastic gorilla glued on it. is like to add a slight bend, but a hammer didnt even do it, so maybe welding and heat would allow a slight bend. still gotta do the covers and then place some VGs to cut the wind noise
