Thread: Rear diffuser?
Old 06-27-2022, 01:04 AM   #22 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
The Bonnevette in Permalink #2 had a duct wall that started at or before the axle line. It walls off the underbody flow from the wheelwell turbulence.
I think the outer wall of a rear wheel spat is optional for the reason you state.
so pretty much i could taper in the rear wheel spat to a straight diffuser, while blocking in the wheel well section from messing with the underbody, then expand that area out and wider from the inner section of the flat underbody/diffuser. dont know if i would both boat tailing behind the rear wheel wells, or maybe just do a mild boatd tail behind the wheel to slighly guide the edge air at the side ends of the diffuser
The Following User Says Thank You to Phase For This Useful Post:
aerohead (06-27-2022)
