Originally Posted by Whoops
I will be very surprised if you get that spot weld to break loose.
You're presuming the spot weld needs to be broken in order to remove the bolt.
The original post says he tried to remove it with a channel locks. My presumption is the bolt & nut may come off as a single unit and simply needs to be busted loose.
