Only around 110g but it's the highest part. I think I will make a small portable lathe from a bench grinder
Also making extended feet. Around 350gsm with wooden kebab skewers inside. Not as strong as the chassis tie, about half, and should put the working height up 9-10 inches. Mixing time with epoxy seems more important than ratio, in my experience so far
