Old 07-14-2022, 05:00 AM   #133 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Unfortunately, most ECUs do not monitor the injectors (none that I'm aware of, in fact) - they're simply two wire outputs, with constant 12v and the ECU provides a controlled ground. There is no mechanism to detect a clogged injector, other than a lean state as seen by the O2 sensor. I'm curious which ECUs you've seen this work with.
mpgmike (07-14-2022)
