I have a picture somewhere of using the handle of one floor jack and my other floor jack to remove the crank shaft pulley bolt in my Accord.
I also could have propped it against the ground, put a jack under the car, removed the stands, lowered the car, and allowed the vehicle weight to break it loose.
Three thousand pounds on a breaker bar should be enough, right?
