Old 07-25-2022, 04:21 PM   #20 (permalink)
freebeard
duckduckgo.com/?q=basalt%20fiber%20environmental%20impact
https://www.sciencedirect.com › science › article › pii › S187661021730022X
A Mechanical and Environmental Assessment and Comparison of Basalt ...
A previous study estimates the energy required for basalt fibre production to be around 5 kWh/kg in an electric furnace, whilst the energy required to produce steel is around 14 kWh/kg [13]. It is expected that this disparity in energy consumption will have an impact on the environmental performance of BFRP.
https://basaltreinforcedcomposites.com › benefits-comparisons
Benefits/Comparisons - Basalt Fiber Composite Reinforcements
Basalt has 20 - 40% better mechanical properties and puncture resistance than Fiberglass. Basalt is very Eco-Friendly, with dramatically lower environmental impact (10 : 1) vs. fiberglass products. Basalt fiber has significantly lower cost than carbon fiber (10 - 15X lower). Green Building Materials For Concrete Construction
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
aerohead (07-25-2022)
